I installed Virtual Vinyl & my system is running Windows 7 & it installed fine. I plug in the Numark box but it does not install the drivers for it.... Am I doing something wrong???
geposted Sun 20 Nov 11 @ 10:09 pm
Are you using a 64bit OS if so the box was made for 32bit. There are new drivers for it on the Numark website but they are rubbish to be fair and not digitally signed for windows.
geposted Mon 21 Nov 11 @ 3:54 am
Yes my OS is 64 bit, so what do I do now????
geposted Mon 21 Nov 11 @ 10:25 am
In the end I bought the DeeJay Trim 4+6 card, was a bit gutted as I liked the VV card. The Trim is alot bigger :( but has more options :). You could try the drivers on the Numark site as well, think they are on beta 2 now (for the past year). Let us know how you get on
geposted Mon 21 Nov 11 @ 10:51 am
you can use the drivers with 64 bit, you just need to enable non driver singing enforcement when booting...
geposted Sat 21 Jan 12 @ 10:51 am
how do you enable the non drivers???
geposted Sun 10 Jun 12 @ 3:22 am
Please search Google for: disable driver signature enforcement
geposted Mon 11 Jun 12 @ 6:56 am
