Hello Forum . Please im having This Numark Dj2go and has been working fine for me.But Since when i had My last Gig The Crossfader has not been working as it was it first.It Slids Oppositely to the side that i do Cross fades to Or the other way round.For Example. When i Slide Left.It pretends Moving Left but will totally not get to the left side where i slides to.It always Remains in the Middle or move the other way which i didint even slide to.Im thinking some of the Beer I was Taken entered the Fader Hole or was it the PC i used that day that did that to my DJ2go Or...... What is it Please.Any Problem.have i Destroyed the Fader with the Beer." Litt;e beer anyways Splited where the Crossfader is and And i know noo Water Entered.....Please I need your Help.Please Help.
geposted Mon 21 Nov 11 @ 6:02 am
Hi Man
I have the same crossfader problem suddenly started to fail by sliding to either side not go so far on the screen is moving before the end for a few seconds, mine is practically new, I've used about 20 times always at home, I thought was the software, I resintale, update the software and nothing, I tried another computer and still fails, the fault is present in a sudden, without any apparent cause
geposted Thu 26 Jul 12 @ 10:43 am
See if the AUTO Video Crossfader is enabled. If it is, disable it and try again.
If the AUTO Video crossfader is not visible in the skin that comes with the Lite Edition, download Home Free version from here https://virtualdj.com/download/free.html and disable that in the Video Mixer center panel, using the default VirtualDJ 2 decks skin. Its a small locker (should be gray instead of orange)
If that doesnt help, do a fresh installation of the software following this .. https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
If none of the above helps, i suspect a hardware issue. You should contact with Numark
geposted Thu 26 Jul 12 @ 10:49 am
Hi
problem solved, I did a clean install and the problem persisted, try the lap of a friend who has virtualdj pro version 7.05 and the failure was hardware, so I got a spray cleaner for electronic controls and the fault disappeared, no there will be as dirty, when not take care covered it with a cover that I did cut the blister, but the problem was solved, I hope this information will serve other users
thank you for your prompt response
geposted Fri 27 Jul 12 @ 8:42 am
