hi I need to buy a new laptop to run VDJ full pro playing mp3's only. I'm playing my first gig in a couple of weeks and my dated Acer is just not up to it , tracks skipping and popping etc . i will only be using laptop for playing music with VDJ & nothing else. 13'' screen would be ample. any advise would be great appreiciated .
geposted Mon 21 Nov 11 @ 6:58 am
Have you considered that tracks skipping and popping may be down to issues with the sound card or with too much stuff running in the background?
I mean, playing a couple of MP3s shouldn't strain any computer these days, even an old one.
When DJ software first appeared, computers were FAR less powerful than they are now, and they managed back then.
Post the spec of the computer. Run the DPC latency checker and see how it performs. Save yourself some money!!!
geposted Mon 21 Nov 11 @ 9:41 am
If you do decide to buy a new lappy go with Asus. I've had mine for a while and its a beast.
Happy Hunting
Huey
Happy Hunting
Huey
geposted Mon 21 Nov 11 @ 10:15 am
Please take a look at https://virtualdj.com/wiki/Performance%20Issues.html
This may help you resolve the problems that you are having with your existing laptop.
geposted Mon 21 Nov 11 @ 2:08 pm
download and run GameBooster it's free and turns off background processes which are what's causing your problem
if you get a new laptop it may very well skip also , but it will look new and spiffy when it does it
also there's a thing called a desktop
geposted Mon 21 Nov 11 @ 6:17 pm
Even if it is only for the use of audio, I recommend that you disable the antivirus in full session, as well as wifi and also the aero effect in case your computer has windows 7, a greeting
As indicated, the software GameBoost is good, cut all running processes and lets his work VDJ maximum performance
geposted Mon 21 Nov 11 @ 6:58 pm
If you are buying a laptop for only audio, you " Dont " need to buy a expensive laptop. The HP Pavilion g6-1c57dx is more than enough.
geposted Mon 21 Nov 11 @ 11:28 pm
