I'm thinking of investing in the ergo and know that it comes with VDJ LE.
I have pro and the latest version and wondered if it would still work with this and if VDJ are releasing any mappings if not?
geposted Mon 21 Nov 11 @ 6:30 pm
Probably have better luck searching the "Hardware" forums but since your here, here ya go, https://virtualdj.com/forums/156031/Hardware_Technical_Support/Pioneer_DDJ_ERGO_mapper.html
Hope that helps
Huey
Hope that helps
Huey
geposted Mon 21 Nov 11 @ 6:40 pm
The Pioneer ERGO is natively supported in the latest build of VirtualDJ Pro Full.
geposted Mon 21 Nov 11 @ 9:00 pm
Thanks for the replies guys. Fantastic. Will the skin the controller comes with work with VDJ Pro too? Does it make a difference?
geposted Tue 22 Nov 11 @ 4:27 pm
The Ergo skin will work fine in the full Pro (You will need to install LE to get it - This can be installed at the same time as Pro.)
However, the skin is optional. Using it or any other skin has no effect on the functionality of the controller itself.
geposted Wed 23 Nov 11 @ 6:46 pm
