Hey all,
I just bought myself an Audio 8 DJ.
I've been mixing with this laptop for 5 years and everything has always worked great. It has no internet, its a laptop that is dedicated for my gigs only. No Antivirus, etc. Running the lastest VDJ version with XP.
Last night I have installed the audio 8 DJ, and I feel like its really resource extensive. It even made my PC lag.
I have installed the Drivers 3.0.
Any recommendation?
Thanks
Any recommendation?
Thanks
geposted Fri 25 Nov 11 @ 12:16 pm
What are the minimum or recommended computer specs for the Audio 8?
What are the specs of your laptop (which is at least 5 years old!)?
geposted Fri 25 Nov 11 @ 6:05 pm
Ive had my best results from using the drivers that came with it. Ive tried updating them before and I had the same problem, try rollin back and see if that helps.
Huey
Huey
geposted Fri 25 Nov 11 @ 6:11 pm
hi,
sorry about that. laptop was a beast back then.
pentium 4 - 3.2ghz
1gb of ram.
as for the drivers, i bought it off ebay and no drivers was included. could i know which version you are using?
thanks
pentium 4 - 3.2ghz
1gb of ram.
thanks
geposted Sat 26 Nov 11 @ 9:33 am
You might need a new lappy but heres a link to the drivers page, http://co.native-instruments.com/index.php?id=freeupdates#Audio_8_DJ
just scroll down till you see the Audio 8.
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 26 Nov 11 @ 9:47 am
i have installed the older driver on the site and it seems to be a lot better.
geposted Sat 26 Nov 11 @ 10:23 pm
