Forum: Old versions
Topic: Can't get sound out of Headphones
I have an iDJ3 turntable and I can't get the sound to come out of them. The only sound I can get from the turntable is my iPod and not from the music I want to mix with my iPod and hard drive on my laptop. I heard the iDJ3 has a sound card built into it, but I can't get the audio to work. The software is a Virtual DJ Broadcast by the way. Please help, thanks.
geposted Sat 26 Nov 11 @ 2:09 am
Sorry, VirtualDJ Broadcaster doesn't support using MIDI controllers such as the iDJ3. It also doesn't support using an external multi-channel sound card such as that built into the iDJ3. Please see https://virtualdj.com/products/comparison.html
To use the iDJ3 as a MIDI controller and use its sound card, you will need to either use the VirtualDJ LE if it came with it or purchase the full VirtualDJ Professional: https://virtualdj.com/buy/
For the correct configuration, please see: https://virtualdj.com/wiki/iDJ3.html
Oh ok. Thanks. I thought that the sound card built in would let the sound onto my headphones with the software.
