hey guys, so a while ago we were discussing setting up the MTP for scratching.... i believe huey made a video... and we had a discussion about latency issues etc.. however, now i cant seem to find it... does anyone have a link please?
geposted Sat 26 Nov 11 @ 4:08 am
geposted Sat 26 Nov 11 @ 4:34 am
ok well, that was no use at all, the first one was for timecode setup,, and the second was the exact same thing.... thanks for the attempt though.
geposted Sat 26 Nov 11 @ 5:52 pm
Go to Google and type in your search criteria followed by:
site:virtualdj.com
site:virtualdj.com
geposted Sat 26 Nov 11 @ 6:35 pm
or you could always check huey's blog...
https://virtualdj.com/homepage/beatbreaker1/blogs/4610/Mixtrack_w__Tech_1200_s_____________.html
geposted Sun 27 Nov 11 @ 12:29 am
site:virtualdj.com
site:virtualdj.com
this i did for about 2 hours... have you ever seen the amount of mixtrack threads there is??
@synth, ill take a look. if not ill just pm huey..
geposted Sun 27 Nov 11 @ 10:00 am
I remember the thread just not the name, lol! What are you trying to do?
geposted Sun 27 Nov 11 @ 10:11 am
i wanna sort out my MTP for scratching and cant remember what i needed to do. i know the latency has to be dropped to like 1250 or something... cant quite remember. the problem i have is when i leave go of the jog it tkes around 1-2 seconds for the trck to continue playing. obviously i need it to be instant.. or at least as close to instant as possible.
geposted Mon 28 Nov 11 @ 12:44 pm
you mean this one... just download the registry tool and change the default sctatch latency, mine is around 980 I think, but I pretty much just set it like huey says in the video, If it's the right one, can't watch it as im using my phone as a modem, and it's shit :(
[youtube]v0emPqYT9oQ&hl[/youtube]
geposted Mon 28 Nov 11 @ 12:58 pm
thans synth, however, i still have a probelm with delay.
the scratch over all i much beter, but i have around 1/2second delay between leaving go of the platter and the track restart. anyone have any ideas how to get rid of this?
geposted Tue 29 Nov 11 @ 7:32 am
The only time I ever experience what your describing is when I push the platter just before I let go.
Sorry couldn't be more help & good luck
Huey
Huey
geposted Tue 29 Nov 11 @ 7:55 am
you need to push the platter forward on release there is a function in how it operates to allow spinbacks, so if you are not pressing the jog and the jog is moving backwards it will spinback the track when in vinyl mode. try this for the mapping, it works in my head, so it might work in reality LOL, but be aware you cant do spinbacks if you use the non holding vinyl mode, but if you hold the button for half a second you it will be in the normal vinyl_mode, so you could do spinbacks...
new vinyl mode button
holding ? vinyl_mode & set 'scratch' 0 : toggle 'scratch' & var 'scratch' 0 ? vinyl_mode 0
jog touchpad
var 'scratch' 1 ? down ? vinyl_mode 1 & touchwheel_touch 1 : touchwheel_touch 0 & vinyl_mode 0 : touchwheel_touch
jog touchpad
geposted Tue 29 Nov 11 @ 8:08 am
