Is there a simple way to add songs to existing a playlist without having to load that playlist?
geposted Sun 27 Nov 11 @ 2:12 pm
The only way I know how:
1. Select the SAVED playlist
Add Songs to it
SAVE as the same filename playlist
2. Create Another Playlist
Save it with Diff Name
Goto the VirtualDj/Playlist Folder
rename the xxx.M3U files to xxx.TXT
OPEN in notepad of one of them and COPY contents then open the other one and PASTE contents
SAVE IT, rename it back to xxx.M3U
3. RENAME the xxxx.M3U to xxxx.TXT
Open it with Notepad
Add the Songs and Path
Save it
Don't forget to RENAME BACK to M3u
4. Maybe use WINAMP or Mediamonkey or any other that reads M3U (I'll just talk about for VDJ) This ithe only tricks I know if I need to add songs to my playlist.
Results are in:
I think the First one is the Simpler one.
Maybe another PROGRAM will do but I don't know or own any myself.
Add Songs to it
Save it
Results are in:
geposted Sun 27 Nov 11 @ 9:37 pm
