Forum: Old versions
Topic: NS7 - Freezing up
Got a brand new NS7 the other day , hooked it up to my laptop which is a HP with Vista 64 running VDJ PRO and downloaded the drivers off Numarks site but for some reason the NS7 was making my processor redline at 100% and it made VDJ keep freezing up ? I never had a problem with my VDJ freezing after hooking up any other controler so what gives ?
geposted Sun 27 Nov 11 @ 3:13 pm
You system most likely does not met the MINIMUM specs for using a NS7.
From their site --
** 64-bit
Windows Vista: Intel* processor, 2.2Ghz Core 2 Duo; 2MB L2 cache; 4GB RAM
Windows 7: Intel* processor, 2.4GHz Core 2 Duo; 3MB L2 cache; 4GB RAM
* AMD Turion or Athlon processor NOT Recommended
What i have is
Processor: Intel(r) Core(TM)2 Duo cpu T6500@ 2.10Ghz 2.10Ghz
Memory(Ram): 4.00 GB
System Type: 64 Bit-operating system
Model: Hp pavilion dv6 notebook pc
Im no computer wiz , is this enough or do i need to have my laptop modified ?
NS7 does hog up alot of processor but seems you have more than plenty of CPU power. Have you tried to stop processes and uninstall programs that you dont need? I use VDJ and NS7 with no issue and i have a 1.8 ghz i7 with 8 gigs of ram. Seems you have the spec for using the NS7 but like I mentioned you may need to stop processes and uninstall other programs if you have not done that yet. I myself had you upgrade my Ram to 8 gigs from 4 gigs but that is just me not saying you need to upgrade your memory that helped me out as well.
Happy Mixing
Charlie C
Try these, as they have helped other people with the NS7.
https://virtualdj.com/homepage/ianmelville/blogs/4540/WINDOWS_7_OPTIMISATION_FOR_VIRTUAL_DJ_GIG_LAPTOP_.html
https://virtualdj.com/homepage/ianmelville/blogs/4560/Optimize_Your_Windows_PC_for_DJing__videos_Pt_1___Pt_2.html
I am also in the middle of making a little app that turns off unnecessary processes for VDJ users.
It’s still in testing but have it working on my system (windows 7 64bit) with only 28 processes running and stable.
Just trying to get that number of processes down a bit more.
Hope this helps
I got so tired of trying to sort all that out personally I got a Mac. Works a LOT better!!
