Forum: Old versions
Topic: cannels 1&2 opposite on dn-mc6000
i have been trying to figure this out for two days now... i have all the settings the way that denon says to have them but now channel 1 is coming out of the mc600 controller on usb3/4 and channel 2 is coming out of usb 1/2 how to get this to revert back because this just started a few days ago when i did the last update for VDJ
geposted Sun 27 Nov 11 @ 4:38 pm
Go to CONFIG -> Sound Setup and check the setting of the drop-down list next to Outputs: External Mixer.
Deck 1 should be on channels 1&2 and deck 2 on 3&4.
Also, see: https://virtualdj.com/wiki/DN-MC6000.html
Okay i'm still confused. I really don't have to get my channels back to regular. My dilemma is that the play buttons and jog wheel work
on opposite channels. I don't know what shift button do you press the right or left Do you hold the browser button down and for how long.
I tried the Registry tool and i have no clue what i'm looking at. tried to re invert mapping still no go. can some walk me through the steps to
get my channels fixed back to regular.
Thanks
Window 7 Asus
Core i5
Dn MC6000
Thanks support but it looks like a no go. Just switch it to 4 decks and I don't see that option.
Whats next...
window7 Asus
core i5
VDJ 7.0.5
Okay finally got it to work. Not sure if you want to make this an important post.. But After trying everything I had the mc6000 connect I went to Config and clicked the Restore to Factory setting. It ask me for login and Password. after inputting my info everything went back to normal and the channels are correct. Right plays right and Left plays left. So Happy its back now lets rock..
Window 7 Asus
Core i5
VDJ 7/0/5 MC6000- 3700
