So I'm planning on upgrading to VDJ pro and I wanted to know if I upgrade digitally can't I transfer the upgraded program to a different computer when I need to? Or is it just the computer you upgrade on? Because I have desk top that I run vdj LE on In the studio and I also run the same serial number on my laptop will it upgrade both?
geposted Tue 29 Nov 11 @ 11:20 am
Yup.It will just be a Serial that will be Given to you.When you upgrade your profile will be registered with your Software including your serial.So there is nothing to panic about.You can Transfer the serial to any computer you want as many PCs as you can but you gotta make sure you do not abuse it cuz It links directly to your profile so you can be monitored with the serial Number registered to your profile and how you using it .Again when upgrading you can chose the option a Digital Di livery or request a CD to it but will cost a little because of the shipment of the CD.Never get Worried.Just Do so and You will Smile^^^
geposted Tue 29 Nov 11 @ 12:07 pm
Thanks for the help
geposted Tue 29 Nov 11 @ 12:11 pm
You are only allowed to have it on 2 different machines, not as many as you want...... 1 machine being your gig machine the second being your backup. It's all in the "user agreement", read it and love it, lol!!
Huey
Huey
geposted Tue 29 Nov 11 @ 12:37 pm
Hey DJ fam.I upgrade my VDJ numark pro with came with LE and now i don't have my upgrade on any PC that i have.Do i have to uninstall the program for all my PCs and reinstall it on the one that i what to use?
geposted Fri 27 Apr 12 @ 7:15 pm
