As I don't use the Sync button at all, I don't have too much experience with it's functionality. On my skin there is a star located to the side of the Sync button labeled, "Beatlock/ Play Sync Onbeat"....What exactly does this mean guys?.....Thanks for the help!... =D
geposted Wed 30 Nov 11 @ 4:22 am
You actualy have a few different options for syncing tracks together, the difference in them is global sync uses the master deck, whereas local sync uses the other deck (probably the active deck)
personally I use match_bpm cause I'm way to lazy to fix the beatgrid of every track which is mainly drum n bass, so wrong 75% of the time because the snare is usually lower in frequency and louder than most other genres.
- sync : synchronize the song with the other deck.
- play_sync : play the song instantly synchronized with the other deck.
- play_sync_onbeat : instantly synchronize the song with the other deck, using local beat information instead of the global beatgrid.
- play_onbeat : instantly synchronize the song with the other deck, using local beat information instead of the gloabl beatgrid, but don't change the pitch.
- match_bpm : set the pitch to match the BPM of the other deck.
- smart_play : when smart_play is activated, songs are automagically synchronized when played.
- masterdeck : select/unselect this deck as 'master deck'. When a master deck is set, all synchronization operations will take the master deck as reference. (for skins with more than 2 decks)
- beatlock : activate/deactivate the beatlock (to keep the songs always in sync, even while moving the pitch).
geposted Wed 30 Nov 11 @ 4:39 am
As always, u da man Syn!!.....Why aren't u working for Atomix yet?....lolol...thankx
geposted Wed 30 Nov 11 @ 4:41 am
Hey, if they ever want an Australian rep I'd be more than happy to oblidge ;-)
geposted Wed 30 Nov 11 @ 5:03 am
