Hi I'm new to Virtual DJ so sorry if this is a dumb question...
I'm trying to create a recording of a mix, but when I mess up a transition or I just want to do a better one, I have to go right back to the beginning of my mix and play/record all the way through to get to the end so that I can have another go at mixing in the next record. Is there any way to avoid having to do this? I just want to cue the mix I have recorded so far at a point like a 30 seconds from the end and then mix in the next record again.
Thanks for your help.
geposted Wed 30 Nov 11 @ 7:15 am
You can try using VDJ with multi-track recording software. Here's a free program that might work for you:
http://www.sonicdownloads.net/download/Audio/Audacity/?f=O2RraF5kS&a=6591&adid=9533935880
OO
OO
geposted Sat 03 Dec 11 @ 11:10 am
Thanks mate I'll give it a go
geposted Tue 06 Dec 11 @ 2:58 pm
