Ok just purchased some new equipment but dont really know how to connect it all......
4 Powered Mackie Tops
2 Powered Mache Bottoms
Numark single cd player
RMX
how do i connect everything to my rmx?speakes?cd player?
I tried running cd player to channel 3/4 input but could not get it to play
RMX
geposted Thu 01 Dec 11 @ 7:36 am
The first recommendation for anything is to read the manual;
http://www.mackie.com/Products/srm1801/pdf/SRM1801_OM.pdf
On page 6, there is a nice diagram showing exactly how to connect all the speakers together. Simply replace the mixing console by the Rmx. Obviously, since these connections are usually made using XLR cable, you would need some XLR to 1/4' TRS jacks to connect directly to the Rmx, although in a live situation, you'll probably have a mixer.
Then for using your CD player as a source to the Rmx:
http://ts.hercules.com/faqs/eng/her_eng_00354.pdf
geposted Fri 02 Dec 11 @ 8:05 am
