Does anyone know how to map a button on the hercules mk4 to toggle from deck 1,3 and deck 2,4. Ive tried the formula virtual dj has in its magazine, but it dosnt work. I can only control deck 3 and 4. Hopefully someone can help me? Thanx,
geposted Thu 01 Dec 11 @ 1:30 pm
try this......
device_side 'left' ? deck 1 leftdeck ? deck 3 leftdeck : on & deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : on & deck 2 rightdeck
this should allow a toggle between 1,3 and 2,4
geposted Thu 01 Dec 11 @ 3:11 pm
Thank you, your formula works great but I realized that its not the formula, because when i input the formula it works but when i restart vdj my controller only controls deck 3 & 4. The toggle button i use still toggles between decks but i could only control 3 & 4 with my controller, meaning i could only press play on deck 3 & 4 and deck 1 & 2 I have to use the mouse which suxs! Hopfully I could get some help if anyone knows whats going on!
geposted Thu 01 Dec 11 @ 4:23 pm
reverse deck
Action: deck 1 invert_controllers & deck 2 invert_controllers
one presses the button for deck 1&2 and another button is pressed for deck 3&4
Pré-écoute PFL
Action: select ? device_side 'left' ? deck 1 leftdeck ? on & deck 3 leftdeck & deck 3 select : on & deck 1 leftdeck & deck 1 select : deck 2 rightdeck ? on & deck 4 rightdeck & deck 4 select : on & deck 2 rightdeck & deck 2 select : select
Or
Action: action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck & deck left select : deck 3 leftdeck ? deck 1 leftdeck & deck left select : deck 1 leftdeck & deck left select : deck 2 rightdeck ? deck 4 rightdeck & deck right select : deck 4 rightdeck ? deck 2 rightdeck & deck right select : deck 2 rightdeck & deck right select
Pré-écoute PFL
Or
geposted Thu 01 Dec 11 @ 4:52 pm
