How do you add songs to playlists that have already been created?
geposted Fri 02 Dec 11 @ 6:10 pm
Open playlist into AutoMix, add whatever you need, then re-save
Good Luck,
Joey...
Good Luck,
Joey...
geposted Fri 02 Dec 11 @ 6:14 pm
to do that you will need to go into -->config -->options -->then "disable" AutoLoad Playlists
then your playlist wont disappear unless you clear it, then you can freely add and remove tracks, to save you need to call it the same thing...
geposted Fri 02 Dec 11 @ 6:17 pm
