Hi, does anyone have any thoughts on this? I am trying to change the video crossfader in VDJ as it is peg to crossfade the video left and right that is the default and can be unlinked but still the crossfader works to fade the video even if it is unlinked. Now here is my question can it be possible to make the the FADER OF DECK 1 to control video on leftdeck and FADER OF DECK 2 control video on rightdeck? i mean instead of using the crossfader to fade video left and right i will use my deck-1&2 fader to fade the video to the mains out like the same as mixing an mp3 audio on your decks.
Should works as when "deck 1 fader up the video will be send/seen in the mains outs and off when fader is down also deck 2 fader up the video will be send/seen in the mains outs and off when fader is down and both video are mixed together when fader of the deck 1 & 2 are both up or half up"
Does it possible to do? Did someone have tried this before? if is it so, then can anyone tell us how to do it? Thank you very much.
geposted Mon 05 Dec 11 @ 1:58 am
Unfortunately you can't "Fade" the video outputs... at least not the way you want to. There's no support for this on VDJ right now. There is a "trick" that you can use to fade the video but this requires to use the internal mixer of VDJ:
In the video options there is a checkbox that's named "Fade Video to black with volume sliders"
If you check this option when you fade down your VOLUME sliders, video output of the decks will "fade" to black.
There's no way to "unlink" this behavior from your volume sliders though...
geposted Mon 05 Dec 11 @ 4:05 am
Thank you Phantom, for the info, so mean the only way to do it is to have both fader of deck 1 & deck 2 up so that it will not be black and mix the video left and right with the crossfader? Do you have an idea if theres plugins for this? that could do the way i want? Thank you so much.
geposted Mon 05 Dec 11 @ 5:21 am
No, no plug-ins either...
geposted Mon 05 Dec 11 @ 5:45 am
