Im looking into buying one of these controllers and I would Like and oppinon on both, Pros/Cons and which one you prefer and why!
thanks for the input!
geposted Mon 05 Dec 11 @ 8:05 pm
the S4 will never be supported by VDJ, you will have to make a definition and mapper for it to work, denon is supported, plug and play, but I say scrap those two and get a VCI-400, It'll a be way better option as it has the functionality the S4 offers and then some, the build quality of the denon and a size in between both.
geposted Mon 05 Dec 11 @ 8:12 pm
The MC6000 is also a stand alone analog mixer. If your laptop crashes, you still have output while your lappy boots up. The MC6000 is a beast. I love it! Plus its plug and play for both vdj and traktor. I think you still would have to map the parameter buttons and knobs for the loop recorder in traktor. MC6000 all the way!
geposted Tue 06 Dec 11 @ 1:21 am
Traktor S4 Disadvantages as i have one and sold it. Quality built is not that good as Denon, then you have limited inputs and outputs as S4 does not have an option to re-route your outs as it is having only 2-mains out 1-stereo TRS 1/4" jack and 1-stereo RCA. No booth output no external records outputs also 2pair of RCA inputs. Soundcard of Tracktor S4 is not good compare to Denon. Also the worst parts of the Traktor S4 is the GAIN knobs which is an encoder rotary types buttons i hates it.
geposted Tue 06 Dec 11 @ 1:48 am
MC6000 all the way!
geposted Tue 06 Dec 11 @ 4:37 am
Denon here as well..
geposted Tue 06 Dec 11 @ 8:25 am
Tried the S4, and went with the Denon.
geposted Tue 06 Dec 11 @ 6:13 pm
