Just got my Denon & am asking you M6000 experts what the optimum settings are to get this beast working? Drivers are already loaded. I just want to use two decks with video & sometimes without vids. Where do I want to put everything at regards to settings etc.?
Thx gang
Thx gang
geposted Tue 06 Dec 11 @ 12:58 am
Inputs: None
Outputs: External Mixer
Soundcard: ASIO -> Then Select DENON DJ ASIO
Open the ASIO control panel and set your latency around 10ms if you plan to work with video. Else you can go down to 8ms.
Finally on the back of the MC6000 select PC and INT MIX
geposted Tue 06 Dec 11 @ 5:03 am
Hi Rob - besides what Phantom has already mentioned, have a peak at the wiki on this one. There is an extensive section on this controller.
https://virtualdj.com/wiki/DN-MC6000.html
geposted Tue 06 Dec 11 @ 8:28 am
As always thx guys, I have it running pretty smooth, but don't want any issues at the first actual gig.
geposted Tue 06 Dec 11 @ 3:31 pm
Many of us have had issues with the ASIO drivers, and use the Widows drivers instead. I do not know if this issue has been solved yet. I just got my my Marathon case today, from Six Star DJ in California. Tell Dave I sent you
geposted Tue 06 Dec 11 @ 5:57 pm
My dennon been pretty good, for few months, suddenly the last Saturday at a gig, the sound was terrible. Any ideas what is happening? I got vdj 7.5 on winnows vista. I haven't change anything at all
geposted Wed 07 Dec 11 @ 5:25 am
