Topic: Software and hardware question.
Does anyone knows of a software that allows me to record my name and play it as a sampler while I'm mixing,and can anyone please tell me which speakers to get for my mixtrack pro? Please keep I'm mind that I just started mixing and I don't know much about anything yet,also my budget for the speakers is $300
geposted Tue 06 Dec 11 @ 11:41 am
If you're using a PC then check out Audacity. It's free, and quite well featured.
Also you could consider using text-to-speech.
Some websites have a page which is used to let you hear examples of their TTS software, and you can type in words, phrases etc. and it will 'speak' them back to you.
It's a good alternative to your own voice if you're not happy with how you sound!
My son and I share a computer.. Laptop, is there a vivrtual DJ software that plays / recognizes multiple decks I have the Hercules RMX and he has the IDJ3 from Numark. I would love to only have one program while we share resources???
Currently I have Virtual DJ Console and he has Virtual DJ LE.
DJ Boldillo wrote :
Does anyone knows of a software that allows me to berecord my name and play it as a sampler
You will need to upgrade to the full VirtualDJ Professional at a considerable discount to be able to load and save custom samples: https://virtualdj.com/buy/
VirtualDJ LE is limited software and only supports recording samples on the fly, which will be lost when you close the software.
Only the full VirtualDJ Professional will allow you to do this. You can upgrade from DJ Console Edition for RMX to the full Pro at a considerable discount by going to: https://virtualdj.com/buy/
VirtualDJ LE and Console Edition will only work with the hardware that it was included with.
Thanks a lot! I rather get the full version of VDJ than having to download a different software.
the full pro version has an advanced configuration control panel that allows you to route external inputs
into the recorder, so you could use a usb microphone and create your own DJ drops with your name......
also everyone will know how cool you are, and you will get laid more
as for the speakers ....i'm guessing you need powered speakers ?.....
http://www.samash.com/p/Tannoy_REVEAL%20601A%20Active%20Studio%20Monitors_-49947200
lLOL @ getting laid.. Thanks a lot chucknorrisyouwimps,I meant what brand and which ones are good for a beginner.
