i have a 1.8ghz processor and a 512 ram plus a 64mb video card on my pc but everytime i play with the virtual dj 5 after a whiel it freezes and the tuen keeps on repeating and repeating over and over again , I have to reboot in order to start over which is why i cant go do my thing in public coz iam afraid that this cpu will do it again? please give me a god advice on this...
geposted Tue 06 Dec 11 @ 5:46 pm
and also i had to install a second virtual dj coz the one with my hercules mk2 keeps on showing protection error 16 and wont operate...i hope you can help me with this..thanks and more power.
daddygrooves214
daddygrooves214
geposted Tue 06 Dec 11 @ 5:48 pm
your computer is very underpowered, The only suggestion I can give is get a more powerful computer... this is the RECOMENDED system requirements:
Intel® Core™ 2 or AMD Athlon™ X2
1280x1024 resolution
Multi-channel DirectX compatible soundcard
1024MB RAM
200MB free on the hard drive
Additional requirements for Video mixing:
2048MB (2GB) RAM
ATI™ or NVIDIA® video card w/256MB of Dedicated DDR3 RAM
Video card must support dual-screen output
Supported Operating System:
MINIMUM: Microsoft® Windows XP SP3 or newer
RECOMMENDED: Microsoft® Windows 7 Professional 32-bit
Microsoft® Windows 95, 98, ME, or older are not supported
1024MB RAM
2048MB (2GB) RAM
geposted Tue 06 Dec 11 @ 7:52 pm
I would highly recommend that after you upgrade your computer - that you also purchase a legal license for the software.
You are trying to run a version that is over 2 years old and the protection error is because you are using a cracked version.
Hope to see you posting sometime about a better system and as a licensed user in the future.
geposted Tue 06 Dec 11 @ 8:17 pm
