I absolutely love the NEW SCHOOL skin with the tech 12's !! It would be even better if the START/STOP buttons on the turntables would fade to a quickstop when pressed like real tech 12's do. Anyway just a thought.
geposted Tue 06 Dec 11 @ 6:07 pm
just install djcel's plugn "brakestart" then if you use the skin to start stop the track, change the mapping of the play button in the xml file to "deck 1 effect 'brakestart' active"
In the plugn there are two sliders, one for start and one for stop... If you want to map your vms4 just use "effect 'brakestart' active" on the play button.
geposted Tue 06 Dec 11 @ 8:12 pm
THANKS SYNTHET1C !!!! I WISH I COULD BY YOU A ROUND OF BEERS FOR YOUR HELP!!!
geposted Tue 06 Dec 11 @ 8:18 pm
geposted Thu 09 Feb 12 @ 10:18 am
