Topic: Multiple Files, Maually Edit BPM's at Once
DJs,
I'm curious is it possible to select multiple files and manually cut the BPM's in half? I have a large number of files that are doubled in BPM and need to find a way to cut their BPM in half in Virtual DJ... I know you can right click on an audio file and manually edit the BPM in half, but I would like to do this for multiple files. Thanks.
geposted Tue 06 Dec 11 @ 9:07 pm
you could try mapping a button to do a macro command
"deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & "
then just repeat the command say 10 or 20 times in one script, you can always hit the button a consecutive amount of times as it will always scroll to the next track in the browser, not sure how glitchy it will be, because it has to load a lot of tracks quickly, but its worth a shot...
deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1 & deck 1 load & deck 1 set_bpm 50% & browser_scrol +1
you could also check out Phantom's database manager tool..
https://virtualdj.com/forums/150056/VirtualDJ_Plugins/_WIP__VDJ_DB_Manager_Public_Beta.htm
