I bought this controller online and downloaded the software it came with, it didn't recognize the controller. So i updated from the 6.1.2 version, to the 7.. The website recognized my controller, but when i open virtual dj le it doesn't recognize the controller.. The controller itself lights up and everything it just doesn't work.. Any suggestions?
Thanks
Jpincay
Thanks
Jpincay
geposted Tue 06 Dec 11 @ 11:03 pm
There may be a conflict on your system that is preventing it from working.
Please see: https://virtualdj.com/wiki/midinotdetected.html
geposted Wed 07 Dec 11 @ 5:19 am
With OSX 10.6 and higher this will help with get it recognized. I hope its not repetitive for you but it has helped others:
1. Using the “Numark Driver Remover” remove Driver version 2.0.2.
2. Restart*
3. Download driver 1.6.9 and install.
4. Restart
5. Remove driver 1.6.9 using the “Numark Driver Remover”
6. Restart
7. Install driver 2.0.2
8. Restart
You will be forced to restart after the installation of new drivers.
2. Restart*
4. Restart
6. Restart
8. Restart
geposted Fri 09 Dec 11 @ 9:47 pm
