i`m connecting all of this .
2* cdj 100s = > bcd2000 (input A,B)
in the cdj100s i put the Timecode CD from this site.
line B is working good. - control the VDJ 7 PRO
the problem is that in LINE A (analog input) is not working
because is a phono/mic input
anyone have an idea what could i do
when i`m replacing the inputs the other cd working to.
if you have an idea what can i do with the input A problem that is to loud
geposted Wed 07 Dec 11 @ 8:26 am
up, can some one help me?
i have a uca200 beringher soundcars and is now working with the advenced config
but i wanna connect both with the bcd
geposted Fri 09 Dec 11 @ 2:58 am
YO?
geposted Tue 13 Dec 11 @ 1:05 pm
You have to use a timecoded cd with reduced volume on the channel of the bcd that has the phono input. If I remember correctly I used Sony Sound Forge to reduce the volume of the TCCD file volume by 48db, the I burned it to a cd & used that cd in the player I had hooked to the BCD2000 Phono Line A.
geposted Wed 14 Dec 11 @ 10:56 am
