Hey guys,
I recently purchased a Numark NS6 but after a few weeks of playing with it i hated it, had clicking noises and lag problems.(i tried all fixes possible)
So i took it back and got a S4, so far just in the first half hour of it im super impressed, its quality built and super portable, im still getting some clicking noises and a little lag, but nothing near as bad as the NS6.
So getting to the point! im just curious about the S2 and its comparison. it looks pretty quality aswell but i noticed some differences such as lack of filter knobs and record/loop buttons. I dont plan on using any vinyl or other deck hookups so the missing inputs are no problem for me.
In the end i guess it comes down to how many extra loops and mashing i will plan on doing. I was just hoping for an opinion from someone who has maybe tried both.
*also i tried switching to deck c and d on the s4 but when i loaded a song it said i couldnt get anything longer then 48 seconds, i figured it would be the same as the ns6 and be able to load full songs?
Thanks guys! just trying to save some cash if i can although i really dont see a problem keeping the S4 its awesome for lack of better words.
geposted Wed 07 Dec 11 @ 6:39 pm
Check this out there are some opinion on TRAKTOR S4:
https://virtualdj.com/forums/157316/General_Discussion/Traktor_Kontrol_S4_or_Denon_DN-MC6000_.html
geposted Thu 08 Dec 11 @ 2:05 am
If you are getting 'clicking noises', then you probably have some underlying performance issues with your computer.
Please see: https://virtualdj.com/wiki/Performance%20Issues.html
geposted Thu 08 Dec 11 @ 5:24 am
If you are getting clicking noises, then there is something wrong with your system, not the NS6.
The NS6 is incredible with VDJ.
Personally, I would have kept the NS6. Seems to be an industry standard now.
geposted Thu 08 Dec 11 @ 8:02 am
my computer is well capable of handling it so it must be somewhere in my settings, before i had a numark mixdeck and it worked well without any problems.
Also i saw that the s4 isnt mapped to vdj, has someone made mappings that i can get? i really enjoy virtual dj but traktor is growing on me :)
pretty sure im staying with the s4, it is quite a beauty im very happy with it.
geposted Thu 08 Dec 11 @ 4:07 pm
I can't tell you where to get it, but if you google something like: virtual dj definition and map kontrol s4, you may be in luck if your willing to pay for it...
geposted Thu 08 Dec 11 @ 4:35 pm
