Hi everyone! I just purchased my Numark Ns6, loaded the new drivers, virtual dj and everything is working great EXCEPT for one thing! The crossfader!! Nothing! right now im just relying on introducing the new track by slowly bringing the channel up, but I want to be able to use the cross fader!! Im sure its some setting that is very simple that I am overlooking....does it have to be activated or something?
Anywho, if someone could help me out, it would be greatly appreciated!
Thanks in advance,
Greg
Thanks in advance,
Greg
geposted Thu 08 Dec 11 @ 12:33 pm
If the crossfader in the vdj skins doesn't move if you tried crossfade your controller left & right then, try to check the crossfader setting maybe it is disabled in the "config" then "option" tab then "crossfader" options if it is disabled just click the that tab and it will change to "smooth, full & scratch. Then if the crossfader in the skins moves when you touch the crossfader in your controller then you must assign your crossfader to the correct channel like switching the cross assign selector to position 1&3 channel on the left and 2&4 channel on the right.
geposted Thu 08 Dec 11 @ 3:44 pm
