Would there be a reason why the <Jog Mode> under VDJ Option settings changes randomly during a continuous set?
I am using DJ2Go and I have the <Jog Mode> on VDJ set to <CD>. I don't scratch on the DJ2Go and since the unit is so tiny, my hands keep accidentally touching the wheel.
However, it appears as if the Jog Mode randomly changes between CD, Vinyl and CD/Vinyl for no apparent reason. Or, at least, I have not noticed any reason. It happens about 4-10 times during my typical 4-5 hour wedding. I keep changing it back to CD, but every now and then, I find that it has flipped back to CD/Vinyl.
I am using Win XP, and VDJ 7.0.5b
geposted Thu 08 Dec 11 @ 1:36 pm
Are ypu holding the load buttons down?? I know if you do it'll switch between jog mode and vinyl mode.
Just kicking ideas around
Huey
Huey
geposted Thu 08 Dec 11 @ 3:16 pm
Hmmmmm.... I could be. I will check that out next time I power up. The question is.... why would it do that and is there a setting to disable it?
geposted Thu 08 Dec 11 @ 7:47 pm
@Huey.... that was it! Thanks for the tip. I checked the mapper and indeed, it was to toggle to CD/Vinyl after holding down the load button for 200ms+. I just disabled that part and we are now good. I still wonder why that was mapped like that... but oh well.
geposted Fri 09 Dec 11 @ 11:14 am
