Can a for example Korng pad KP3 or KPquad Be added to a dj set up that uses a Numar Mixdeck and what it would offer to a DJ soory for the question i am a new dj trying to learn. I have the numark mixdeck and i am wondering if a can add a pad and what would be the best option to choose a KP3, KPquad Or other. please give me advise.
geposted Wed 14 Dec 11 @ 1:54 am
unless the mixdeck has an effect send on the mixer (which I doubt) you would only be able to use the kaoss pad on the master output, wired in between the speakers and the mixer.. or you could use it as a midi cotroller, however if that is all you need you could save a few hundred and just get a nano pad, there is instrustions on djdads blog of how to define and map the x,y pad to use in vitual dj. but if you wan't my opinion you should stick with tactile controls for effects, I have a KP2 somewhere... touchpads are very imprecise and impossible to replicate an effect when required
geposted Wed 14 Dec 11 @ 2:04 am
Thank you for your advice and support
geposted Thu 15 Dec 11 @ 1:54 am
