Hi, does anybody know if the numark mixtrack is compatible with the Broadcaster version of the VirtualDJ?
geposted Thu 15 Dec 11 @ 3:06 am
Mixtrack will work with the supplied LE or Pro versions only. Broadcaster does not support multi channel sound cards.
Keith
Keith
geposted Thu 15 Dec 11 @ 5:31 am
Broadcaster does not support using any MIDI controllers (It's for mouse+keyboard only), except for 10 minutes at a time as a trial of the full Pro.
As above, you will either need to use the VirtualDJ LE if your MixTrack came with it or upgrade/purchase the full VirtualDJ Pro: https://virtualdj.com/buy/ - If you have LE, you can upgrade at a discount.
geposted Thu 15 Dec 11 @ 6:04 am
