helol , when i try to transfer a music file to the usb the transfered file corrupts or like the music cuts or start in the middle
geposted Thu 15 Dec 11 @ 4:56 am
always verify your tracks that you're transferring are good to go in the first place. than try another usb drive. maybe the one you're using has some corruption and needs to be junked. you could also try reformatting the drive and then transferring. assuming this isn't some kind of crazy buffering bug and you're not transferring while your system's already under a larger load, otherwise just xfer while your system is doing nothing else.
geposted Fri 16 Dec 11 @ 12:40 am
Another problem that you may be having is that if you have turned off your background intelligent transferring system in Windows operating systems and you're using a computer at the same time it is quite possible that you are creating the corrupted file by trying to transfer and having that background intelligent transferring system off.
You can go into services and check to make sure that you do have that on while some people prefer to have that off for better computer CPU usage it's actually really handy to have fun especially if you're using virtual DJ and you're running things directly off the hard drive.
DJ KAACE
DJ KAACE
geposted Fri 16 Dec 11 @ 7:26 pm
