i installed virtual dj which came with the idj3 i bought and as i click on open to open up virtual dj i get a message saying "Invalid Skin File ( Error line 0 in the xml) i need to know how i can take that message off and be able to run virtual dj...
geposted Thu 15 Dec 11 @ 7:50 pm
if you have a cracked copy of vdj on your computer you need to remove it first including the "my documents" vdj folder, as the le version won't load up a skin that's not native to the version you have for the id3. you should also make a backup of the database and playlist files as they should be able to be transfered directly into le by placing them in the newly created vdj folder, I am not certain about that though as I have never used LE.
geposted Thu 15 Dec 11 @ 8:04 pm
Please read this
https://virtualdj.com/wiki/Invalid%20Skin%20Error.html
If the above will not solve your issue, contact support https://virtualdj.com/contact/
geposted Fri 16 Dec 11 @ 11:39 am
