Forum: Old versions
Topic: Hercules RMX buttons 1 to 6
Hi all!
Is there a way to change the 'actions' behind the buttons 1 to 6 on the RMX? For example button nbr 6 is standard a beatgrid. Can I change this?
Thx
geposted Fri 16 Dec 11 @ 12:48 am
if you upgrade to pro you would be able to map it to a different function. there are a lot of options at your disposal, for effects though you just map
effect "effect_name" active & on
eg... effect "beatmasher_group" active & on
when you have a registered pro serial you will have access to Duen Duen's amazing new effect.
but the list of everything you can map is here
https://virtualdj.com/wiki/VDJscript_verbs.html
also check out the script wiki for instructions on how to map
https://virtualdj.com/wiki/VDJscript.html
I thought those buttons were djc buttons? Try holding one down cause I think a menu will pop up and you can reassign them to a bunch of different things.
Let us know
Huey
