Hi everyone,
I'm writing this, cause I'm desperately looking for a solution for my very annoying problem that simply prevents me from mixing..
I have MAC OSX Snow Leopard (10.6.8), VMS4 Controller (updated with last firmware), and last VDJ version (v7.0.5b).
I have 2 kinds of problems:
1) the most annoying one (because it happens every minute): the configuration window pops up without any reason (I do nothing special to make it appear). I just noticed that when I'm connected to the Internet, the problem does not occur. Do you have any idea how to fix that ?
2) Sometimes, I don't understand why (this is maybe linked with the first problem), my controller buttons are not recognized by Virtual DJ any more. To fix that, I have to start/quit VDJ (or touch the options) at least 5 times, as if my controller were not fully supported... strange...
I also must say that before this version 7, I've installed some cracked (maybe buggy) versions 6 of the soft, and because I became pro, I decided to purchase it. Maybe, the older versions have not been completely cleared after having installed this version 7, thus causing the bugs I have. This is just a thought... I'm not convinced.
Thank you so much (in advance) for your help!
geposted Sat 17 Dec 11 @ 7:22 am
You can read some post on this forums and maybe you can get related answer on this:
https://virtualdj.com/forums/148819/PC_Version_Technical_Support/VDJ_7_0_4___VMS4_Issues_____.html?search=vms4&page=2
geposted Sat 17 Dec 11 @ 8:09 am
Thanks for your answer cesarcastillo, but i didn't find my problem on this topic. Moreover, this topic is about troubleshooting with PC version of VirtualDJ, I have a MAC...
geposted Sat 17 Dec 11 @ 8:43 am
