I have a Hercules mk4 which came with VDJ6 LE, and does allow recording of mixes. I am looking to upgrade to a Hercules 4Mx which comes with VDJ7 LE. Is it still possible to record mixes with this version of the software, or would i need to uprade to VDJ7 Pro...?
geposted Sun 18 Dec 11 @ 6:40 am
VirtualDJ Limiited Edition versions allow audio recording. You don't have to upgrade to Pro Full version to have this feature.
geposted Sun 18 Dec 11 @ 1:42 pm
I have a macbook 2,1 I'm trying to record a cd while playing using VDJ7 and a Hercules controller. When I play it back the sound is breaking up. Is this a memory issue?.....Help
geposted Fri 13 Dec 13 @ 11:58 am
If you're attempting to burn a CD live as you play, then I would suggest not doing that!
Record to a file first, then burn the file to CD using a slow burn speed.
geposted Mon 16 Dec 13 @ 7:10 am
or use an external recording device....like reloop mixtape ore others
geposted Tue 17 Dec 13 @ 10:52 am
