How much would it cost me to upgrade the supplied software (VDJ 3 LE) to VDJ 7 Pro?
geposted Tue 20 Dec 11 @ 1:48 pm
If you go to your profile and add the serial number from the CD sleeve, that will make you a LE user.
You can then go to upgrade VDJ Pro Full and it will tell you how much the cost is.
The discount differs depending on what controller and LE version you have.
Keith
Keith
geposted Tue 20 Dec 11 @ 1:57 pm
I havn't brought one yet as I wanted to know how much the upgrade would cost first.
Thanks
Thanks
geposted Tue 20 Dec 11 @ 2:01 pm
OK, no problem. Maybe one of the teamers will be able to advise this for you.
Keith
Keith
geposted Tue 20 Dec 11 @ 2:04 pm
Krad congratulations on making moderator !
geposted Tue 20 Dec 11 @ 3:21 pm
Cheers Chuck!
Keith
Keith
geposted Tue 20 Dec 11 @ 3:40 pm
