Hi everyone,
I would like to know if its possible to use the iRemote app and any midi controller both at the same time? I would like to use the iRemote as a stand alone effect controller (if ever) so I dont need to use my keyboard controls. Any information would help!
TIA! and Happy Holidays
geposted Wed 21 Dec 11 @ 1:54 pm
Yes, you can use them both together.
Keith
Keith
geposted Wed 21 Dec 11 @ 2:18 pm
Hi Keith,
Thanks for the info! Is there any specific set up for this? Does it work for LE?
geposted Wed 21 Dec 11 @ 2:26 pm
I believe it does .... check your LE version has the remote tab in config settings.
Keith
Keith
geposted Wed 21 Dec 11 @ 2:30 pm
Alright will do. Thank you again. :)
geposted Wed 21 Dec 11 @ 2:53 pm
No problem, give me a shout if you need any more info.
Keith
Keith
geposted Wed 21 Dec 11 @ 2:57 pm
LE versions do not support the iRemote application, except during the 20days of trial period. They are designed to work exclusively with the controller that came bundled with. You will need to upgrade to Pro Full version in order to use both your controller and the iRemote application at the same time.
geposted Wed 21 Dec 11 @ 5:35 pm
errrr too bad. but I could try the 20 day trial though. haha. but I'm planning to upgrade soon. Got alot of things to pay up for Christmas, so its not yet on my list.. Thanks for the additional info, Cheers and a happy holidays!
geposted Thu 22 Dec 11 @ 10:45 am
