Topic: is it worth it to upgrade?
Hello,
What is the upgrade cost of VDJ LE to Broadcast? or Broadcast to PRO? and is it worth it and why?
I'm a starting DJ have had some gigs but don't feel experienced yet. Any advice would help! Thank you all!
geposted Thu 22 Dec 11 @ 6:01 pm
Don't. Your MixTrack won't work with VDJ Broadcast. The only option you've got is to go Pro. And I certainly recomment it ;)
If you're logged on, click on Buy and you'll find out what your rebat will be because you already own a LE-version.
pro is way to go
https://virtualdj.com/products/comparison.html
I also have the Numark Mixtrack Pro and I think is better for you to polish your skills using the LE version and than upgrade to Pro,the upgrade is totally worth the money plus you'll have unlimited downloads.
Good luck!
Your also forgetting that the current Atomix policy is to give FREE upgrades. So if you upgrade to PRO now, you will get VDJ8 PRO for FREE when it is released. That in itself is worth the upgrade price.
Cheers,
Roy
Yup PRO is the way to go! Download all the effects, skins, tools, samples, remap your controller, add multiple controllers to your setup, advanced config, multiple soundcards, the list goes on.......
Upgrade, you'll wonder why you waited so long
Huey
Invest to VDJPro - You'll only purchase once and all the next updates are free of charge.
Thank you all for the advice! I am upgrading it !
Dj Nico
@ngonzalez
Enjoy your upgrade! You wont regret it!
hi ive got virtual dj le and i have a choice of the cheap path of upgrading directly or go for the 300 quid option and buy virtual dj pro straight from atomix is there any difference between the upgraded version of virtual dj pro and the 300 quid disc version of virtual dj pro?
None whatsoever. Upgrade is the way to go and you will be able to download the current version and updates directly from this site.
Keith
