when im pressing the icon to open VDJ, its asking me to put in my login and password. i do that and its telling me its wrong
geposted Fri 23 Dec 11 @ 2:06 am
Check the Firewall Settings on your PC and check also if VDJ hasn't been blocked by ANy Antivirus or anything and also check if your VDJ is uptodate... Thats the advice i can give you for now...
Wish it Helps..
Thankx.
Spinash
Wish it Helps..
Thankx.
Spinash
geposted Mon 26 Dec 11 @ 3:49 pm
if the above does not work then go to support/help tab and get a ticket and put all this in your ticket and support team will get back to you in a short time.
triggs
triggs
geposted Mon 26 Dec 11 @ 6:16 pm
well MAC hasn't got fire wall, but its doing it on my W7 lappy.
like, i can get into the website via VDJ when i go into config blah blah blaaaa.
its just at start up i have this prob, its not a big issue, the thing is b4 last week i was ok, and now its not ok.
thanks anyways guys
thanks anyways guys
geposted Mon 26 Dec 11 @ 7:46 pm
