So some weird stuff is happening on my VDJ, IDK what to do with it and this hasnt happened before. So this happens with every track every time, and i cant seem to prevent it unless both tracks are at exactly the same BPM, but when they arent the same, for example an 87.5 BPM dubstep track vs a 110 BPM house track, when i press play on the 2nd one to switch from one to another, it automatically syncs it! so my 110 bpm track syncs to 87 and it sounds like complete Sh*t!
a more detailed explanation of the example is:
on the 87 BPM track, theres a section that builds up from 2 step, to 4 on the floor, to double kick (2 kicks per beat per measure) and so on until it reaches a full climax, breaks down for 2 measures, in those two measures theres a sample, and then the drop, thing is, id like to switch the the 110 bpm track, which has a similar situation, so after the climax on the 87 bpm track, id switch right at the sample to the 110, crossfade all the way to the 110 and then at that point that 87 one would be out of the question. only issue, when i press play on the 110 bpm track and switch over, the 110 automatically syncs down to the 87 bpm track, so the sample sounds awful, and the drop that soon follows even worse! i dont have any beatlocks activated, and I dont even think my VDJ has the Auto Sync option.... WTF?! someone help PLZ!
i have a gig coming up soon and i absolutely need to play these two tracks, i dont have time to figure out another way around it!
thanks!
thanks!
geposted Sun 25 Dec 11 @ 5:22 am
On the default skin there is a padlock beside the deck play button. If it is lit gold then click to change it to white.
This is probably because your smart play is locked on.
Keith
Keith
geposted Sun 25 Dec 11 @ 10:25 am
