Hello, My Numark Mixtrack Pro won't play music through the Virtual Dj LE software it came with. The first time I installed everything it worked great I got off to go eat dinner & came back and now it won't play. Can anyone help me out here? I have the right sound card in the settings all the volumes up. I have no clue what else it could be,
Thanks.
Thanks.
geposted Sun 25 Dec 11 @ 3:46 pm
How do you have your MTP set up? Have you checked your settings on the config menu? My VDJ software reset itself the first day after I installed it after that everything is running the way it should.
geposted Tue 27 Dec 11 @ 12:55 pm
what is the MTP?
geposted Tue 08 May 12 @ 4:56 pm
(M)ix (T)rack (P)ro.
geposted Tue 08 May 12 @ 5:32 pm
