Hi there
i have just started using my VDJLE DicoveryDJ Pro and i decided to record a mix, which is fine but is it possible to add some kind of cue point at the place where a new track begins (in the middle of each mix), so that during playback i could still select an individual track rather than having to fast forward to it?
thanks in advance
Mick
thanks in advance
Mick
geposted Tue 27 Dec 11 @ 6:52 am
I believe you can select the option to cut the track when you crossfade. It won't work if your a scratch Dj though or you'll have to use a program like Nero or something along those lines.
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 27 Dec 11 @ 8:56 am
you can map it in pro, don't know if you can map your keyboard in LE
record_cut : cut the current recording to a new file (or new track if recording to CD)
geposted Tue 27 Dec 11 @ 10:00 am
Thanks fella's
geposted Wed 28 Dec 11 @ 8:19 am
