Just paid for the $49 ver of VDJ. I was told I could use it on my Mac Laptop with USB Headset, and main external output jacks for the main sound. The FAQ says "If you are using a laptop (Or desktop with stereo sound card), you can add a basic stereo USB sound card for the headphone output. Your computer's built-in sound card will be used for the master output and the USB card for your headphones (Plug your headphones into the USB card.)".
The FAQ does not say whether or not I setup the Mac Settings for USB Output or Line output. Nor does it say it will TIME OUT in 10 minutes, which it does, but the FAQ does not say that, and according to the feature chart, it says it supports Master + Headphones. If this is true, then why do my settings time out in 10 minutes on limited version?
And finally, if I'm not able to resolve this issue, then what are the procedures for getting my money back, and if I have the $49 version, is it also not allowed to spin for commercial use? There is NOTHING in the FAQ, Documentation, or any other online literature that says the $49 version is not allowed Commercial use. I was also told from some other users that the $49 version would allow me to pre-listen to my next track with the USB Headphones.
Why is my version not doing it?
geposted Tue 27 Dec 11 @ 7:26 pm
geposted Wed 28 Dec 11 @ 12:09 am
Broadcaster should allow you to prelisten. I personally have never used it so I hope its just a config issue.
I believe the commercial restriction applies to the free version, not any of the paid versions.
geposted Wed 28 Dec 11 @ 5:20 am
