I have recently purchased a Hercules MP3 e2 controller but I am getting a delay between my speakers and headphones making it impossible to mix, can anyone help me to solve this problem?
geposted Fri 30 Dec 11 @ 10:14 am
You might want to give us more detail about the soundcard you are using as well as your computer specs (Operating system, processor speed and memory) if you want useful help for your problem.
geposted Fri 30 Dec 11 @ 10:27 am
I am using a USB (UB-003) sound card, it is a 5.1 sound card which was what i was told to buy with it, the sound card appears to be the problem as everything you play through it now (ie dvds or iplayer) seems to have a delay, do you think i should replace the soundcard?
geposted Fri 30 Dec 11 @ 10:53 am
comp specs I am not 100% on, it is a pretty new laptop running windows seven, plenty of memory
geposted Fri 30 Dec 11 @ 10:57 am
