Forum: Old versions
Topic: Require help quick! Changing from PC to Mac
Hi, i'm trying to download vdj pro which I currently own a license for, to run on my macbook pro. However I only get the option to download the windows version in download centre. Is there any way I can download the Mac version and use the same serial code? I run vdj with a hercules mk2 console, and this is the software which I own. Have a party tomorrow and I still have to compile my virtual database, so any quick responses will be greatly appreciated.
Cheers
geposted Fri 30 Dec 11 @ 6:17 pm
You will need to register your Pro serial number to your profile on the page https://virtualdj.com/users/edit.html
You should have received this when you upgraded.
If you have lost it, please contact support: https://virtualdj.com/contact/
Once registered, you can download Pro for both PC and Mac from the Download Center: https://virtualdj.com/download/updates.html
NOTE: If you didn't upgrade and have been using DJ Console Edition v3.4 for PC, then the version of the console that you have is the older PC only version (There was no Mac version of v3.x) You will need to upgrade to full VirtualDJ Pro at a discount to be able to use it on a Mac: https://virtualdj.com/buy/
