Hello fellow VDJ members,
I have just upgraded my Virtual DJ software from V5 right up to the latest V7, but when I updated it, none of my database history of my mostly played music on a regular basis has transferred. This is the music that is at the top of each folder that you select and then you have the music you don't play often further down.
Is there anyway I can get around this?
Thanks,
Tom.
Thanks,
Tom.
geposted Fri 30 Dec 11 @ 9:58 pm
You should have went from 4 to 5 to 6 to 7.............
Good Luck
Huey
Good Luck
Huey
geposted Fri 30 Dec 11 @ 11:16 pm
There is no way around it then?
geposted Sat 31 Dec 11 @ 5:15 am
Nope....
geposted Sat 31 Dec 11 @ 9:08 am
If you have a registered version of VDJ Pro you can request older versions to allow the transition between databases correctly. If you don't have a licence and are using other versions of the software then there is nothing Atomix can do to help.
Regards
Keith
Regards
Keith
geposted Sat 31 Dec 11 @ 10:32 am
