Does this work with VDJ 7 on windows XP? I rad in another message it doesnt but I want to use it with my XP laptop... I see there is a mapper file... what exactly does it control? is there documentation for the mapper file?
geposted Sun 01 Jan 12 @ 10:38 pm
No it does not work on XP.
It does not follow the device detection rules for Windows XP and therefore not supported on that platform by VirtualDJ.
geposted Mon 02 Jan 12 @ 12:42 am
is there something you can recommend that will work? I just want to have a controller to supliment my CDJs and mixer to have control over functions of VDJ
geposted Mon 02 Jan 12 @ 12:57 am
You could consider the Zomo MC-1000 if it's available in your country:
http://www.zomo.de/en/Products/MIDI-Controller/Zomo-Midi-Controller-MC-1000.html
Otherwise, simply upgrade to Windows 7 and then you can use the DN-HC1000S.
geposted Mon 02 Jan 12 @ 12:03 pm
Dam I wish that they made a version that didnt come with a soundcard, Id sooo get one!!
Huey
Huey
geposted Mon 02 Jan 12 @ 12:24 pm
I dont need a sound card either.. I just want a midi controller so I dont have to use mouse and keyboard..
I cant upgrade my laptop to WIN7 as it doesnt have enought memory and isnt supported. when I get a new laptop, I will be OK but for now I have to find a controller to work with XP
geposted Mon 02 Jan 12 @ 12:34 pm
Try looking at the Korg Nano series. There pretty good for the money and I think they work with XP. Or look up the NI X1.
Good Luck
Huey
Good Luck
Huey
geposted Mon 02 Jan 12 @ 1:35 pm
Think of it this way -- if you get the Zomo product then you have a back-up sound card with you at all times. You don't have to use the sound card part in order to use the MIDI capabilities.
geposted Mon 02 Jan 12 @ 3:36 pm
True but without the soundcard the price should come down, lol!! Would look dam good sitting above the Ecler though........
Huey
What is this in US dollars, please, 299,00 EUR
All I can find is exchange rates and thats not helping me......
Huey
geposted Mon 02 Jan 12 @ 3:56 pm
