I have been scouring the internet for days now trying to figure this out. All I can find information on is how to use timecoded vinyls.
I want to play REAL vinyls from my turntables through my Hercules RMX through Virtual DJ 7 Pro. In 5.2 LE you could just press the source button and it was playing. In 7 the best I can do is set it to Microphone and get one turntable playing without any mixing controls.
This seems to be something very fundamental and basic, yet nobody has even mentioned it.
geposted Wed 04 Jan 12 @ 9:10 am
The best way to search this forum is to use google with "site:virtualdj.com" in front of the query, that restricts google to only searching this site for your question. I would use something like "site:virtualdj.com timecode bypass"
but just so you are clear you need to map "linein" to a button on the controller, or you can hit the AUX button on the default skin
geposted Wed 04 Jan 12 @ 9:20 am
Ah yes, excellent. Thanks for the good advice!
geposted Wed 04 Jan 12 @ 9:27 am
