Hi. I have mapped standard shift button and another one variable on other button ( set "myshift" while_pressed ). The thing is that i want to have 3 actions on one knob. without pressed buttons it should be normal action effect parameter 1. If i press SHIFT i would like to have GAIN function by knob. Third action is with mapped before MYSHIFT while pressed that would control FILTER option. Is it possible to do that?
geposted Wed 04 Jan 12 @ 4:00 pm
It's possible to map it in the full version of Pro or during the trial. To do it you would need to map either two shift buttons or use a cycle shift to one button.
just so you know, you can call a shift anything it doesn't need to be called "my_shift" it can be called "gainshift", "filter_shift" "vdj_rules" "anything"... It doesn't matter what you call it as long as you query it on the button/slider/knob/jog you want to shift.
shift 1
set "gain_shift" while_pressed
shift 2
set "filter_shift" while_pressed
knob
var "gain_shift" ? gain_slider : var "filter_shift" ? filter : effect slider 1
or you could use a cycle shift
cycle "vdj_rules" 3
knob
var "vdj_rules" 1 ? gain : var "vdj_rules" 2 ? filter : effect slider 1
If you have pro already you should register your serial so you have access to the bonus downloads.
shift 1
shift 2
knob
cycle "vdj_rules" 3
knob
geposted Wed 04 Jan 12 @ 8:55 pm
Thanks a lot for your answer. that was exacly what i need. Greetings.
geposted Fri 03 Feb 12 @ 4:25 pm
Is someone able to advise how to set my fx select knob on the MTP to adjust a loop by +/- 5ms when the shift button is active, but still choose effects when it's not?
It's a rotary knob, that 'clicks' as it turns (like a car stereo volume knob), and turns indefinitely.
Ta
Mike
Ta
Mike
geposted Sun 30 Jun 13 @ 6:31 am
this should do it... post back if you have any problems
var 'shift' ? param_smaller 0 ? loop_move -5ms : loop_move +5ms : effect select
geposted Sun 30 Jun 13 @ 7:38 am
Fab. Where do I stick this code?
I've gone into mappers, hit 'Key Learn', press SHIFT, (which defaults to "toggle "shift_loop", then copied and pasted your code above in there instead.
Now what happens is , my shift button is permanently flashing, and when pressed, a list of my effects appears wherever my mouse pointer resides. Furthermore, I am unable to increase or decrease the length of loops (by 1/2, or 2x).
If it makes any difference, I'm using the 'MixTrack Pro:ver 1.1' skin.
Restoring to factory mapper defaults fixes everything again.
Am I being a simpleton, and missing the obvious?
Ta
Mike.
Ta
Mike.
geposted Mon 01 Jul 13 @ 3:22 pm
you need to map it to the encoder not the shift button, but use this instead as your shift name is different.
var 'shift_loop' ? param_smaller 0 ? loop_move -5ms : loop_move +5ms : effect select
also skins make no difference to your mapping.
geposted Mon 01 Jul 13 @ 11:12 pm
Sorry...
The encoder? Is that the effect select dial?
Ta
Mike
Ta
Mike
geposted Tue 02 Jul 13 @ 12:33 pm
yep
geposted Tue 02 Jul 13 @ 10:47 pm
Works like a charm.
Thank you SO much!
Ta
Mike
Thank you SO much!
Ta
Mike
geposted Wed 03 Jul 13 @ 12:56 pm
