I have bought a Numark DJ2GO and it came with Virtual DJ LE lite,is or will this be supported by the Virtual DJ 8 Upgrade.just curious if i will get the new update or not.
geposted Sat 07 Jan 12 @ 12:37 pm
you won't automatically be upgraded to vdj 8, you will need to purchase the full version of vdj pro to get vdj8, i'm not sure if you get a discount from owning the lite edition, but type your serial at the bottom of the below page to see if you can get a discount
https://virtualdj.com/buy/
geposted Sat 07 Jan 12 @ 12:44 pm
ok,thanks,it says i get a $30 discount. but being 14 i don't have that amount of money lying around,will be saving up for a while,but as long as Virtual DJ continue to do the Home Edition for free i can try VDJ8.i have just seen a mistake with my comment,i meant a VDJ 8 LE version
geposted Sat 07 Jan 12 @ 12:52 pm
as in will i get an upgrade to Virtual dj 8 LE
geposted Sat 07 Jan 12 @ 1:09 pm
not unless numark approve the upgrade, however unfortunately they probably wouldn't even consider it as you already have all the functions that numark agreed upon, everything else has been striped away. You will be able to download vdj8 home when it is released, however you will only be able to use your controller for the first ten minutes when you open the program.
geposted Sat 07 Jan 12 @ 1:17 pm
Ok,Thank you
geposted Sat 07 Jan 12 @ 1:26 pm
